Cookie Settings and login issues
Postby GreenLake » Thu Apr 23, 2015 11:18 pm
A slight change to the board's cookie settings was needed. If this causes any issues, the fix is to clear your browser's cookies for daysailer.org and forum.daysailer.org.
Some people have reported login issues, where the login doesn't "take". We are looking into that. Clearing cookies may help.
Re: Cookie Settings
Postby GreenLake » Fri Apr 24, 2015 12:03 pm
Normally, the "Delete all board cookies" link at the bottom of the index page should work to clear all cookies associated with the forum.
There are also browser-specific ways to view and remove cookies, see https://kb.iu.edu/d/ajfi
If you use multiple browsers, each keeps its own cookies.
Re: Cookie Settings and login issues
Postby GreenLake » Mon May 04, 2015 4:49 pm
Some users report not being able to view images ("not authorized"). That's usually due to login failures.
If none of the methods above have helped, clearing the browsers entire history is another option that has
worked for some.
Postby GreenLake » Tue May 10, 2016 8:04 pm
Note, you can check whether you are correctly logged in by noticing that the top-right of the page says: "Logout [ Username ]" where "Username" is your user name.
We keep getting reports that people have login issues, but didn't see this message.
Return to Events
